D
Deleted member 174758
1950s brickwork you should be able to use shield anchors
Resin anchors: for a 14mm threaded anchor you drill 16mm holes in your frame first. Offer the frame up to the wall and spot mark where holes need to go. Dril the holes (SDS drill) then blow out any debris with a pump. "Dry holes" where you hit a void in the wall need to be avoided (not used) and redrilled elsewhere. Using a gun pump the resin into the hole. Some resins can be used in a heavy duty 300ml caulking gun - the type we use is about 1-1/2 to 2 times the volume and needs a specialist gun. The resin needs to fill the hole about 1/5 or so (you aim for 10 bolts per resin cartridge in decent masonry or concrete with the Hilti resin we use) - it is a 2- pack system and the mixing occurs inside a special mixer nozzle, so for this reason you have to pump all the resin first in a single quick session. Partly miced resin goes off very fast in the nozzles. Once the resin is pumped you screw the threaded rods into the holes taking care to thoroughly coat the anchor threads in the resin (hence screw NOT push). The resins generally take 10 to 30 minutes to initial set point at which point the frame can go on the wall and washersand nuts applied, but only done up finger tight. The frame may need temporary support for a while. Most anchors will carry a good load after a couple of hours and can be tightened then. I normally visit after 24 hours to tighten fully. For professional guns we always request spare mixer nozzles (70p or so a pop) which allows us to break off resin filling if needs be - I don't know if they work with the 300ml cartridges
Note that where the frames won't be seen we'll often fix the frames temporarily to the wall with 6mm screws and brown plugs, with additional temporary supports and drill straight through the holes in the frame. It's a lot faster.
