I need to hang a 6ft by 3 ft tongue and groove gate between a side entrance. I have a 2x4 pressure treated post which I need to attach to a side brick wall from which to hang the gate.
Will a size 7 brown rawl plug and using four equally spaced 5x100mm screws suffice to securely fix the timber post to the brick wall?
Only asking because most of the tutorials I've seen use either masonry bolts/screws or frame fixings and since I already have some brown plugs and 5x100mm screws thought it would achieve pretty much the same result rather than going out and buying some more kit?
Any advise appreciated.
