I am currently renewing a large cold roof which has rotted from the inside, no ventilation or vapour barrier with a GRP top. The roof is on a dormer where the roof joists joined directly onto to the ridge beam with no ventilation and no scope to convert to warm roof due to ridge height. The roof is 9.5m wide by 3.5m span. I am going to fit PIR between the joists leaving the 50 mm ventilation gap, and add a vapour barrier under the ceilings (all the plaster board is down).
However to get the necessary ventilation my options appear to be to cross batten with 38x25 slate batten and fit a 25mm continuous vent along the short ends which would mean a 9.5m ventilation span.
But I wondered if I ventilated at the fascia as well giving ventilation on 3 sides would this help or cause a problem with ventilation paths?
Another option would be to cross batten and then add mushroom vents as well as belt and braces but I would rather not have unnecessary penetrations in the roof if it can be avoided.
Any thoughts or advice would be much appreciated.
Thanks,
Jason
Thanks,
Jason
