Flat Roof Problem!!!
7 Sep 2007
hi
can anybpdy help
i want to change my flat roof into a pitched roof has any body got any plans or any suggestions
cheers
Is it a garage, extension, outbuilding or into a exsisting roof?
Ground floor extension with a lean-to pitch roof? really need more details if you can
Hi
i have measured the roof it is 5m x 3m and from the roof to the 1st floor window is 1m
can this be done for the right pitch and could any body tell me how to do it
cheers
you are asking a question that is impossible to answer, without the right information or even a site visit.
you normally bed a wall plate to the inside skin of the building and then pitch the roof off the plate. the ceiling joists then span from one side of the plate to the other.
or, if it's trusses, simply fix them to the plate using truss clips.
next fit the fascia and soffit.
you then felt, lathe and tile the roof in.
fix the gutter and you're away.
