Thats rubbish warm roofs can equally be applied to flat and pitched roofs.
There should be no condensation formed in the rafter space either as.
1. sufficient insulation prevents warm air reaching the cold under side of the roof.
2. a properly installed vapour control membrane and foil backed plasterboard should prevent moist air from entering the rafter space
Ideally abreathable undersarking should be used to let out any moist air trapped during construction also some insulatin should be placed either above or below the rafters to prevent thermal bridgeing.
