- Joined
- 17 Sep 2004
- Messages
- 465
- Reaction score
- 10
- Country
The house is in a mews where all the houses have flat roofs. Company 1 recommnds Triflex (2 quotes with/without insulation depending what they find). Company 2 recommends fibre glass. Pros and cons of materials? Prices realistic?
COMPANY 1
Quotation option 1 (Cold roof)
Price includes:
-Scaffolding
-Remove all the roof
-Remove on the back side coping stones (carefully so we can use them again)
-Remove front ridge (carefully so we can use again)
-Remove old lead flashing
-Remove old plywood OSB board
-Check condition of the roof joist and change where it is necessary
-Instal new vapour barrier green membrane
-Add new 18mm WBP plywood
-Add 4 coats (triflex) waterproof membrane on top of the plywood
-Supply and instal new lead flashing (code 4)
-Pointing of brick wall where it is necessary
-Put back copping stones and ridge
-Clean and remove all the rubbish
Price: £14,200+VAT
Quotation option 2 (worm roof)
Only extra materials and labour:
-18mm WBP plywood £700
-100mm Kingspan £1320
-Labour £1200
Total: £14,200+£3,220=£17,420+VAT
Triflex roof specification please check on the ling (https://www.triflex.co.uk/systems/roofs)
COMPANY 2
Quote for flat roof replacement
* to erect scaffolding to property
* to remove ridge tiles adjoining flat roof in order to carry out flat roof works
* to remove existing flat roof covering
* to re-board flat roof using 18mm osb boards
* to install new grp edges and trims to roof perimeter and upstands
* ro install new code 4 lead outlet roof gulley
* to install new grp fibre glass flat roof using premium quality resin and matting and finish using graphite grey top
* to install new grade 4 lead flashings to brickwork adjoining flat roof
* to re point walls adjoining flat roof
* to re fix ridges tiles after flat roof installation
* take away all rubbish
* new flat roof carries a 10 year guarantee
Total 13,500
COMPANY 1
Price includes:
-Scaffolding
Price: £14,200+VAT
-Labour £1200
COMPANY 2
Total 13,500
