Remove the double socket and back box and replace with a 1+1 back box then 2 fcu's with flex outlet
Sorry for sparking up an old thread but I have a similar issue and plenty old Apple extension plugs like this around. My plan was to patch this flex into a multi socket but the fuse on these Apple plugs is only 3A. I'm no electrician so I'm assuming the flex will only be rated to 3A too and simply putting a 13A fuse into that plug probably isn't a good idea? I don't plan to load these sockets with any massive loads but does anyone know what the limits are of uprating the fuse?Although convoluted, expensive and not the most practical - the slimmest plugs I have come across are GENUINE Apple Mac (non-rewirable) power leads; available on eBay for around £5:
The GENUINE cables are three core - copies are usually two core.
In addition, you would require a flex connector to cut and join your cables.
Hence the impracticality of this solution!
Are you using approximately the full 6ft length of the lead, or do you plan to make it a bit shorter?My plan was to patch this flex into a multi socket but the fuse on these Apple plugs is only 3A.
Hmm, I thought all modern 13A duraplugs were the same size and shape, regardless of the colour.The white Duraplugs seem quite thin, but I don't have one to hand
I don't see any markings on the lead sorry, was probably getting in the way of Apples feng shui! ... Could easily make it half the length, would this help with the loading? I've got 25mm to play with so the alternative would be to swap the two gang socket for a 'flush' plate version (seems to be about 4mm) then use a standard 20mm plug. Although if this Apple lead option is a go-er it'd be a lot easier!Are you using approximately the full 6ft length of the lead, or do you plan to make it a bit shorter?
On the side of the lead there should be a wire CSA marked - something like 3 x 0.75mm2?
Thanks for your help, think I'll go for the sensible slimmer sockets option, standard 13A plug and not burn my house downThe lead is unlikely to be more than 3x0.75, which means the biggest fuse you can use is 5 A.
