If copper is too tricky for you then you could use plastic pipe and fittings for ch pipework.
must be careful on flexi pipe technology as a lot of jobsworths plumbers would not be able to rip people off charging £100 to fix a 15 m cold water pipe burst. instead some people with half a brain may be able to fix the leak themselves
people with half a brain might not dredge up ancient posts for no reason,
Maybe there's a bit of a braided flexi-hose fest going on at the forum tonight.
strange ? i worked in a petrochemical plant and stainless steel flexi hoses where the norm ther for fitting all sorts of things from 10 mil up even attached to high pressure and high temp turbines and boilers hydraulics i was the stores buyer
I saw a replacement updated combi DIY fitted. The man used flexible push-fit leads (with de-mountable Speedfit type of ends) to connect onto the existing pipes. It was a neat job and hidden under boxing. He said he checked the specs on the flexible pipes and it could be run with CH. The gas was copper with a few compression joints.
It worked well and I can't see a regulation that says it is illegal.
