From below, comes up from the floor and the final stage fitted with a flexible connector with service valve. The whole thing is concealed no pipe work on display, which makes cleaning easier
It is possibly dodgy as the service valve is not accessible unless you move the pan away from the wall. However the regulations said nothing about accessibility, only that you had to have a service valve where it entered the cistern which it does.
The only bit I did not like was that I had to leave the 3.5" lead waste in, as I could not find anything to replace it with. I had hoped to change it for plastic, like I did on the sink and bath, but I could not find and suppliers on 3.5"/90mm plastic waste pipe.
