can anyone give me some advice, i am about to lay a real wood floor on concrete (15+ years old).
due to the restricted height i can take the floor level up (approx 25mm) because of the front door i need to keep the make up to a minimum.
my proposal is to lay a dpm (advise on suitable product), lay 4mm ply floating on the dpm and glue the real wood flooring directly on to the ply, i intend to leave a clear 10mm gap the entire way around the room so effectively giving 20mm expansion over 5m.
i need to know which glue would be suitable for this, preferably a quick cure glue due to time restrictions i have.
i also need to know if my proposal sounds sensible or if it's heading for problems later in life.
thanks in advance.
thanks in advance.
