floating real wood floor
That's up to you. We don't use strappers, but then we install flooring all days so are used to treating things with due care.
I got the floor down, went for 3mm dpm then laid boards directly on top.
Problems encountered with laying though
1: the boards are far from perfect with a small error of a few mm in board widths (158mm > 162mm) is this normal?
2: the error in board widths meant that i couldn't get a tight fit between boards so therefore had to use tension straps after all.
No, not at all! How long are the boards? 4mm difference on 160mm wide boards doesn't sound like quality to me. The supplier can't blame it on not sufficiently acclimatising, you've left it for a week in the house, didn't you?
the boards range from 500mm to 1500mm long, they were clearly half price for a reason then...
i honestly expected the flooring to go down alot easier and would not recommend this flooring to anyone, tension straps are my saviour. unfortunately i still have the hallway to do, should be alot easier now i know what to expect.
i am not going to go back to the supplier because i was able to lay it and it looks really good, i'll just learn never to use them again and to bad mouth them to anyone and everyone.
and yes i did have the boards in the living room for a week before laying.
thanks for all your help and advice, i'll recommend you to anyone i know that needs flooring advice.
garry
Always be wary if short lengths are offered (if you're able to find out in time before buying). Mostly are 'left-overs' from different batches.
Normal quality flooring can come in various lenghts but should contain also much, longer lengths and a proper mix between shorter and longer ones.
As we say: quality comes at a price, but saves you in the long run (time, frustration etc ;))
Hi wood wizard where di you get your flooring from.
I have just brought some quality flooring £62 per sq m and have laid a couple of bits together and there is also a gap of a couple of mm at one end. I am now worried lol :LOL:
Wood you like whats your site address please.
