Hello,
We are doing an extension, and the ground floor is a Forterra Jet Floor (concrete beams with polystyrene infill). The beams can only be supplied in 50mm increments, so in order to get the required span we end up with the beams projecting 40mm into the 100mm cavity at one end. Forterra say we can trim this overhang off with a disc cutter.
My question is, do we actually need to cut this off, or can it just be left sticking into the cavity? Given that it doesn't bridge the cavity, I couldn't really see the need. Would rather not cut prestressed beams if the extra length isn't causing a problem.
Jack
Jack
