I'm not really au fait with anything other than simple structural masonry design, mainly because where I work we almost always put frames or piers in when removing walls, and leaving lengths such as shown on your drawings without such lateral resistance isn't something we would ever do.
However, I believe your engineer's thinking goes something like this:
She is taking the view that the masonry is spanning vertically between the floor and ceiling, and is therefore restrained top and bottom. Joists are spanning in the wrong direction to give restraint so she must be ensuring the floor and roof are both well strapped to the wall (which they should be).
This assumes that the floor and roof are both stiff enough to distribute loads to the shear walls.
However, you've got limiting dimensions for wall panels, and you've also got some window and door openings breaking up the wall in the horizontal direction, so the windposts are there to give restraint in the horizontal direction.
The windposts under the 254 UC are there to deal with the lack of restraint at the first opening.
The windposts under the 203 UC are probably there to help with the minimal restraint where the new wall meets the existing...
I'm sure your engineer has considered the wall's stability and is happy that there is nothing to worry about. But ask her and let us know what she says. I'm interested in her answer and might learn something!
Deanomy might come back and give a better explanation...
