If the clear span sleeper wall to sleeper wall is 2.8m, I suspect your 4" joists are already over-spanned. I usually work off the old (pre-TRADA) span tables, which are more generous than allowed now, and even these show only 1.87m for 4x2 @450 centres.
Also, your notching is not that near the end, and you will therefore be effectively weakening the joists further. If you have to notch on alternate joists, do as the others have suggested and strengthen with 3x2 glued and screwed on the sides. These pieces do not have to go the full span of the 4x2 - 4 or 5 ft long pieces would be OK so long as they are firmly fixed.
