So in my case shall I remove it and replace with something else to level the floor? i'm trying to understand why you can apply a screed of between 1mm and 6mm using self levelling compound but not a sreed of the same thicknees using premixed sand/cement mortar (very fine sand)? Unfortunately the self levelling compound has not worked for me because I can get a lot of sun in that room and eventually the heat from the direct sunlight has cracked it twice.
