Floors dug up - should we put in underfloor heating??
Yep, bad choice of words....what I meant was as it runs cooler it uses less energy, so less Kw/h. I really need to stop doing these on my phone.
If a house is held at a mean average temperature above the outside when you don’t need it (are at work or sleeping) then there are losses all that time. If the house is allowed to cool down to outside temperature there are no losses.
It is the same argument that some try to claim it is cheaper to leave heating on low all the time. It isn’t.
To warm a room requires a certain amount of energy based on the heat losses of that room. That amount of energy remains the same however you provide it. If it runs cooler it must run for longer.
Have to disagree ... UFH is run cooler so use less energy per Kw/h ... it also works on averages ... so it holds the house at a mean average temp and then raises that temp slowly when required rather than cold to hot ... cold to hot as with a normal convection system. The mass also acts as a thermal storage, releasing that energy slowly.
The way it heats the space is much more efficient and minimises drafts and cold spots so the air temp doesn't need to be as warm, as with convection radiators, to actually feel more comfortable, UFH can hold the air temp 1 or 2 degrees cooler than convection rads to 'feel' just as comfortable (an air temp that is run 1 deg cooler can save up to 10% in energy costs) . Radiators use convection so the heat rises to the ceiling and therefore takes more heat to get the air at the user level warm enough, whereas UFH work more on radiation from below and as the heat rises the living level space is kept warmer, again more efficient.
All in all it works out cheaper to run if used properly, has a longer lifespan and doesn't stress the boiler/system components as much.
runs cooler but heating a helluva lot more water so explain how that is cheaper
I doubt it’s possible to make a clear judgment on which is most efficient. I’m not convinced things like Nest and similar, and weather compensation, give any noticeable advantage either. Does anybody know of any trials by official bodies (or anybody else without wanting to sell something), to compare? It wouldn’t be at all easy to arrange a number of properties in identical situations and operating regimes, apart from the system being trialled.
My own experience, for what it’s worth – when I first had a house with CH, both out at work all day, so had it coming on and off on the programmer. When the kids arrived, started leaving it on 24/7. Didn’t notice any increase in gas use and found for same comfort could have the roomstat 1-2°C lower. Been doing that ever since.
In an evening, you can set a fallback temp, say 15°C.
If, in the morning the temperature was above this level, the floor won’t fire-up.
I haven’t found my bills any dearer than previously, radiators in the house. Ufh in extension.
Apart from initial warm up time, ufh is far more efficient than radiators in my opinion, and more comfortable.
it is more complex than heat in = heat out
conventional wall radiators are at least 80% convectors -so the air temperature is highest at ceiling height -around 2 foot above a standing person
underfloor heating is mostly radiant and heats the room with the highest temperature at floor level -so far more efficient at heating people.
That agrees with my experience with 24/7 heating. IMO better to keep a steady temperature rather than cycling, and better for the house structure.
This from The Energy Saving Trust:
Is it cheaper to leave the heating on low all day or turn it on only when I need it?
Energy Saving Trust, the idea it's cheaper to leave the heating on low all day is a myth. They're clear that having the heating on only when you need it is, in the long run, the best way to save energy, and therefore money. (A timer's best as your thermostat turns your heating on and off to keep your home at the temperature you set.)
The key thing to understand here is that it's all about the total amount of energy required to heat your home.
It's a given that a certain amount of energy is constantly leaking out of your home (how much will depend on how good your insulation is). The Energy Saving Trust says if you're keeping the heating on all day you're losing energy all day, so it's better to heat your home only when you need it.
Radiant heat will not heat the room. It heats people, the rest passes through the windows. But I'm not sure that I believe underfloor heating is mostly radiant anyway.
But the heat, is being released from the slab, even when the boiler is not running, so no gas is being used. So it’s not costing gas usage.
I think the whole argument comes down to where it is installed, how it is installed and how it is used. If it is installed as a complete package with good insulation and used properly it seems there are efficiencies to be made over traditional CH running costs. Whilst I cannot find anywhere case studies that state that UFH is more efficient, I also can't find any that says it isn't, in fact the information I seem to be able to find is that the jury is still out.
That being said, I retrofitted my downstairs to overlay UFH with wood, tile and carpet topping and have dropped my gas costs by over 10% in the last year. The house is much more comfortable, the whole space is much more evenly warmed, one room that had 2 radiators totaling 3Kw never seemed to get warm enough or there were cold spots/draughts, there's no longer an issue with that and the UFH rating for that room is now approx 1.7kw (22m2@76Wm2) So my experience is that it certainly is more efficient. That and the cooler system (boiler currently set @ 50deg) means less stress on my system, so there are efficiencies to be made in other areas too.
Added to that I now run my stats @ 19Deg which is 2 deg less than I did before - The energy savings trust states that dropping a room temp by 1deg can save up to 10% in energy costs - so in my experience it's a win win.
Swing and roundabouts I would have thought, while the slab is warming gas is being consumed with hardly any heat being emitted
Edit: that was to post#28:)
