- Joined
- 17 Apr 2007
- Messages
- 2,555
- Reaction score
- 129
- Country
Is it an open fitting, electronic starters generally are not suitable for enclosed fittings, they do not like the heatElectronic starter it is!
Thanks for advising.
Consider changing your fluorescents for LEDs.....?
Instant start, much brighter light and becoming cheaper all the while. The only issue I have with them is that the cable has to enter at the ends which may be an issue over existing wiring.
John
Where did you hear that, any evidence to back it up?Is it an open fitting, electronic starters generally are not suitable for enclosed fittings, they do not like the heat
A question that probably deserves it's own new topicWhat's the future for fluorescents? Are they being manufactured in decreasing numbers now? Does anybody specify them in new installations nowadays? Do they have any advantages over LED or other types of lighting any more?
John
Much cheaper to buy, yet similar cost to run (for the same light output)?What's the future for fluorescents? .... Do they have any advantages over LED or other types of lighting any more?
Electronic starters have been used in enclosed fittings for years without issue. Many Thorn (enclosed) fittings came with electronic starters in them from the factory, as did some Fitzgerald fittings and probably many others.
I recall seeing them labels before & wasn't sure why they were unsuitable, I've always politely ignored them. Some older electronic starters had issues with certain types of switch start circuits, 8' 100w being one of them as well as some leading circuits. Modern starters will be fine with them. The Fitzgerald slim light packs often came with electronic starters within the fitting itself, placed right next to the (hot) ballast.We tend to service lots of older Dustproof fittings in Licensed premises and often next to the starter holder is a Manufacturers label stating "Not suitable for electronic starters", Thorn I recall mainly used there own make Vivatronic starter modules rather than twist fit starters, I also found Fitzgerald tended to use normal starters branded as Fitzgerald, these days I encounter more High Frequency fittings, so no evidence at the moment,
