Flourescent starters
Can you get electronic starters for series operation, such as two 18w tubes in series on one ballast?
Got x3 starters at the local Arrow Electrics for £1.08 so job done.
Will give LED replacements some thought. Actually already have x2 of these in the garage. There's a channel topside with the two terminal connector to accept a cable from above. x2 slide clips for fastening to the ceiling.
Thanks All!
Thanks All!
Well think about what I wrote.
The lumens per watt for florescent and LED tubes is similar. A 5 foot LED tube is less than half the wattage of a 5 foot florescent and also less than half the output. So you will need 2 LEDs to replace one florescent. Can't see that as an advantage.
LEDs have better optical control, so usually you do not need the same amount of lumens to get the same lux level
That's true, coupled with the fact that, as I have often observed, it seems that fluorescent lighting was often over-specified.
As I've said in the past, I have replaced a good few fluorescent tubes with LED ones of the same length (i.e. about half the power) and, in every case, the amounting of lighting I ended up with was perfectly adequate (suggesting that the fluorescent was probably producing an amount of illumination which was 'more than required').
Kind Regards, John
I assume you mean they are more directional. Florescent tubes used to be available with a built in reflective strip to direct more light downwards, but I've not seen one for a while.
It really depends on whether you like dark ceilings I suppose.
The two, as the link above, I have in the garage seem adequate enough.
