Surely if you are cooking on an electric hob you are producing steam as well as cooking smells? They need to be removed from the room.The reason why we have a cooker hood is to remove the water and other combustion products from the kitchen, there is no need with an electric hob.
By product of burning gas, nothing to do with the water in the heating system.this condensation is coming from
Thanks for all the inputs, however I am still stumped by where this condensation is coming from. From what I understand, the combustion chamber heats the heat exchanger, water passes through the exchanger and is heated to the desired temp, and then either exits a tap or is pumped around the rads.
The gas flame is heating a metal block, so no water produced there. It must then be produced by the evaoporation of the water in the heat exchanger, in which case, how does that work ? If CH water is evaoporating and used as latent heat, isn't the CH pressure going to drop ? Either that steam exits the flue or condensates in the trap and exits the boiler.
I must be missing something here.
but we also use gas when cooking and I don't see any water byproducts when turning the hob on.
Some vapour/steam.What are you expecting to see?
Some vapour/steam.
The induction hob I use has a boil/simmer selection, so very little steam produced, it auto drops to simmer, and I don't cook anything which does not smell nice, I actually now do have a cooker hood, but only the lights are ever used.
