Where does the condensation happen ? So the heat exchanger is where the combustion transfers the heat to water, but where does the returning CH flow and the flue gases meet ? and from what I've observed condensation can take at least a few seconds, and thats a long time when talking about the movement of gas.
I think the flue gases are routed over the cold part of the heat exchanger by the fan, on their way to exiting through the flue. There's several different designs of heat exchanger these days. But the easiest one to visualise, I think, is a radial coil type heat exchanger. I found this video really helpful. Especially at the exact one minute point, where it shows the burner's placement within the combustion chamber, and how the flue gases flow over the coil. I've been told by a very knowledgeable poster that this is probably the world's most common heat exchanger, and is used in several major brands including Vaillant.
