Posted this recently but maybe to wrong area - trying again
redoing my flat and plumber has installed a 45 degree angle to save one meter of run on 100 mil flue pipe. flue comes out into small courtyard which has an exterior wall run of only about 850.
IF he had drilled hole in the right place the termination point would have safely in the middle of the wall - over 300 mill from one corner and 300 mil from another . Problem is the termination point, while safely over 300 mil from one end, is about 230 mill from the other - and exterior corner of the property.
I am just a punter but I know the regs call for the pipe to be 300 from all corners. He says he will certify it but I wonder if i go to rent the place will I not get a safety certificate when some other heating/boiler engineer says it is not ok. Plumber is a good guy, knows what he is doing it seems, but I am loath to go on with this as is, but also loathe to have him come and move it a
He says regs are relaxing some and it will be fine. Builder agrees. just don't want to have to make a change at a later date for lots of money...
any advice. Need to move on this - make a decsion in next day or two as the build will go on...
thanks
PC
thanks
PC
