If you've got a smart phone you should be able to download an angle measuring app. Handy for things like this.
I suppose it depends on your phone. Mine seems pretty accurate (within 0.5 of a degree) when compared to the spirit level and gives angles to 0.1But how accurate are they for measurements of just a few degrees?
Not sure how many other manufacturers do it, but I note that Baxi have incorporated a catchment tray inside their boilers to drain the water down through the condensate. Not a bad idea, and cheap to do.It's not an ideal problem per se it's a flue design issue and flue siting issue.
I believe ideal have spoken to M and G who make the flue for ideal and other manufacturers, about changing terminals with a bigger lip on the air intake and a hole just after it to let water run out.
May be worth phoning ideal/developer and explaining the situation and even though it's out of warranty they may look at it.
I'm having the same issue, and it's an Ideal boiler. How did you get on when you called them?I'll let you know how I get on with Ideal and I am going to complain to the developer, just for the hell of it!
