I've owned this for less than two years and probably used it half a dozen times but when I went to use it today, the display was misbehaving...
When measuring voltage, it would activate the "Hold" function and switch on the light and then not allow me to switch either of these off. It would on occasions, show no voltage reading on display but the 230v indicator is clearly lit.
I have replaced the batteries and will also be contacting Fluke as I believe that I have a two year warranty. The auto-test also completes successfully each time. Is this a known issue and does anyone have any suggestions?
Also, I assume the voltage indicators are always the accurate indicators of voltage.
Thanks in advance.
Thanks in advance.
