In that case I agree that you would not need 'long and narrow' light sources.I wouldn't.
Kind Regards, John
Why do that in preference to buying a purpose-designed LED light which properly exploits the characteristics of LED emitters over something compromised in order to mimic a different type of light?Indeed - so remove the ballast or get a fitting designed for LED tubes.
Hmm.In that case I agree that you would not need 'long and narrow' light sources.
Ask yourself this - if you were designing a light from scratch, why would you make the emitters narrow tubes?
If I wanted to illuminate a long/narrow work surface and wanted to reduce shadows?
I wouldn't.
You can get fluorescent tubes also with built in reflectors. Although the modern LED is better than the old fluorescent, if you compare with modern fluorescent then the gain is rather small, if any, I only have one HF fluorescent at home, I fitted it when working on the building of Sizewell B and it was second hand, I renewed the tube about two years ago, so lasted around 25 years, (top of stairs so used a lot) what we tend to do is compare the new LED with old fluorescent and the old wire wound ballast fitting needed a tube change at around 4 years used in a kitchen.Indeed - so remove the ballast or get a fitting designed for LED tubes.
Indeed, and the same over my desks and work surfaces. However, it's not necessarily that there was previously 'more light than required' falling on the desk/work surface - it could be at least partially because, previously, some of the light output of the tube was being 'wasted' (turned to heat, which one might not want) by going sideways and being absorbed by dark walls.
Kind Regards, John
Fair enough, but I imagine you can understand that it was not clear (at least not to me) from the words that you actually wrote that such was what you meant.What I meant was that even if I had to illuminate such a work surface I would not make the emitters narrow tubes.
That might be "ideal" in some senses, but it could also be argued that it was unnecessary, and possibly 'wasteful', if all one really needed to be decently illuminated were a desk or surface along one wall of the room.Surely the ideal is for the entire cieling to have a uniform glow which lights the space as evenly as if it were open to the skies at noon on an equinox at the Equator, and that therefore one should strive to install light sources which approach that ideal as closely as possible?
Do you know I thought about adding "on an overcast day" to "at noon on an equinox at the Equator"My hobby is photography "at noon on an equinox at the Equator" is not best lighting, some clouds do help.
But that's not the sort of lighting I was talking about - as you go on to say, in reality we want an even spread. In nature we very often don't - imagine no more glorious sunsets.I want shadows, but not harsh shadows and we do all sorts to get light where we want it when in a studio. And since we want it to look reasonable natural often that means one single light source with reflectors to illuminate selected areas.
So to light a room making it look as natural as you can, single bulb on the ceiling white of course and some white translucence diffusers below the bulb to emulate the clouds.
Traffic lights used to be like that, which was useful if you weren't quite looking because as you caught the start of the change you could look directly and see it finishing to change.If we had always had lights which intrinsically ramped up to full brightness over a short but noticeable period, and then someone invented a light source which instantly sprang into 100% output,
You cannot, the end caps are different and so is the length of the tubes.The only HF fittings TLC do state 58W tubes. I assume you can run the 54w HO ones in there.
HF 58W fluorescent fittings, with Activa 172 tubes in them - which are as close to daylight as you can get, 6500K and CRI of 98.if you were to kit out a garage right now, from scratch, what would you go with?
