You need to check how far the power is reaching, only then you can start to solve the problem.jonnyfishing said:I should start again by checking for power from......
1) Ignition switch to blower switch
2) Blower switch to blower motor
If you have power at the motor,the fault will be on the earth side of things.(try an earth wire direct from the battery to the blower motor)
