We fixed the thermostat by ourselves but then the water pump started leaking.
Just before Christmas, we gave up and put the car in to replace the water pump and give it a service. £300 odd quid and 5 days later, the radiator hose started leaking.
We fixed the radiator hose but the engine kept overheating.
We took it back to the same mechanic as we thought he should have pressure tested it.
He said he did but has now said that the head gasket has a leak in it and that the cylinders are putting air into the cooling system creating airlocks and causing the car to overheat.
I have four questions.
What is he taking about? Shouldn't the cylinders be separate from the cooling system? What does the head gasket actually have to do with the cooling system?
Should he have picked this up when he fixed the cooling system and serviced the car?
Can we fix this ourselves and how would we get rid of the airlocks?
thanks in advance
thanks in advance
