Re: CL locking problem and Alarm on automatic Y reg - April 2001
Hi, I found this thread after searching for a possible cure to my focus locking problem.
I believe the other day someone tried to yank the drivers side handle, it was pulled out if that makes any sense, anyway... all seemed well. Then last night, for some strange reason, after locking the car, I tried the handle of the drivers side rear door, and it hadn't locked! [Wonder for now how long it hasn't been locked!] I can only now lock that door by internally pressing the lock lever. And likewise, to open the door, I have to reach inside and press the door lever.
It was whilst standing outside the car I realised this morning that the light above the clock, which is normally flashing when the alarm is set wasn't flashing! I have been out and tried some of your recommendations, I have sat inside and manually pressed the drivers side door lock in and out for a good half a dozen times and that seems to now have resulted in the flashing light coming back on and flashing.
I still haven't been able to get the key fob control to undo the central locking on the rear door, or that matter, if it was unlocked, the key fob will not lock the rear door.
I have located (on knees and with torch) the siemens box you suggest taking out the cables for. Well I think I have. It's under the shelf under the steering wheel, almost against the area where the wheel arch is. It definitely says Siemens on the box, Under it are two bundles of cables going into two connectors. Being really stupid, any tips on removing these connectors. I presume, I DO NOT pull out the wires!. there seems to be a slight lever to depress, but I can't get it to depress (It could be I'm not trying hard enough, and also I'm rather scared incase I make it all worse and damage something!! )
Maybe it would be easier if I post a picture? But any tips would be very gratefully received.
Thank you Calley x
