Foundation bodge for 2ft high wall
28 Feb 2018
Going to take a stab at some bricklaying and after a bit of advice please...
Will be building a 2ft high single skin wall to create a raised flower bed in the garden, research points to a pretty standard concrete foundation anything up to 600mm deep.
Thing is I have a load of 6" concrete gravel boards going spare - would digging a trench, bunging a bit of sand in it, then laying the gravel boards flat on top serve as a usable foundation?
I know I should do it 'proper' but just wondering...
It’s more to do with digging down to a stable sub soil, but for a 2 foot high wall you don’t need a lot of foundation. I’d deffo pour a strip of concrete a few inches thick. guess your method may possibly work if you’re lucky. Seen Victorian 6foot high garden walls built on basically nothing, still going strong.
You're supposed to tie them in together somehow, so you could make it like lasagne with a layer of mortar between each board.
If these were the 12" boards I'd say "yes" but 6" is not much wider than the wall and so the load is not being spread out enough sideways to prevent the wall leaning.
If you could lay two side by side an two course high (and bonded), and then one on top centally, then that would be much better.
18" deep shouldbe OK if the top soil has all gone at that depth and the ground is firm.
Don't use just sand to level them as it will wash out. Mix with cement, semi dry.
Thanks for the advice, 12" concrete foundation going in deep to hit the clay - too much messing around at that depth to get gravel boards level enough to be usable.
Now for a new post with next stupid questions...
