Framing advice
...and this idea of building the walls on the ground and then lifting into position, only works if the base is absolutely level and the house wall is dead plumb? I doubt either are...
I've got my base as level as I can. I think that's good but unless the wall is at 90 degrees from the base, it might be safer to build the timber walls on the base?
Either way that works, of course if your house walls are on the pee then the panels need to take account of that, your base should be level in anycase.
