- Joined
- 27 Jan 2008
- Messages
- 28,109
- Reaction score
- 3,409
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
In the living room we can either watch Freeview direct on TV or through the set top box, the set top box also has satellite, which the numbers start as Freeview finishes, and it is now connected to mothers bed room so she can continue to watch end of program when in bed, also anything recorded on the set top box, which has a 2 TB hard drive connected to it.
This means when mother goes to bed can't really swap channels I need to swap from set top box to Freeview built into the TV, or go upstairs and watch it on a Sky box.
With Channel 10, 14, 15, 19 and 20 the numbers always seem to be the same, some times the program does not exist, but if there numbers are the same.
However with higher numbers there does not seem to be any set order numbers like 801 can be anything. The set top box often asks if it can re-search for channels and I often find channels have gone or arrived back, not a problem when you have time to find the channel, but when looking as one program ends it's a real pain.
Upstairs is even worse the Polaroid TV has analogue 1 ~ 99 and digital only starts at 100, some channels I can remember the Sky number, at least they don't change.
So the question, is it just my TV's or do all Freeview TV's swap channel numbers around all the time, is the only way to have static channel numbers to use Sky?
