I have a French manufactured ceiling spot bar. New build flat with normal ceiling rose. The French fitting has no clearly marked live or neutral, so does it matter which way round I connect them? There is also no earth, but the fitting is metal, so should I take feed and earth the metal housing anyway?
Takes GU10 spots, will they work with the dimmer switch?
Many thanks..
Many thanks..
