fridge freezing up
24 Sep 2005
Yorkshire
hello!
I read a topic similar to my problem.
The plate at the back of the fridge has a block of ice at the bottom left, which drips into the drain channel and freezes that.
I suspect the pipe behind is leaking.
But, there's a screw holding the plate and a plastic bung.
Does that mean it can be taken off and replaced by removing these and pulling the plate forwards?
There are pipes going from the plate out of the back of the fridge, but do they just pull out with the plate?
Thanks.
John
if you mean the plate inside the fridge
check the thermostat actually cuts out
put the fridge on its warmest setting too
check the little wire coil for the thermostat is ok too
if the back is freezing then its TOO cold - thats all
Thanks Cakeman.
I'll look at that tomorrow/today and get back to you.
It's saturday night and I just got paid...
Typing this from under the boardwalk.
Too many sherbets.
thank you.
John. :D
No smiley for drunk?
