Hi All,
I would be grateful if someone could help me out here:
I have the following issue. I have a wire which is underground and it goes to a plug which is plugged in to a socket.
Using the above I want to connect the wire to a light switch then from then from the light switch I need to go to the ceiling spot lights (4 Spot lights), is this possible?
So that means one side will be in a plug then light switch then into the spot lights.
Can someone please tell me how I can achieve this? With detail information on what wires I need and colours please?
I have 1 MK light switch and 4 spot lights high voltage I brought from Wickes.
