Hello
I have what could be a very simple and silly question but I was wondering if one of you lot could enlighten me.
I'm having a combi boiler installed in the loft space and because it's insulated it can get pretty cold up there so I've been advised to get a froststat, specifically they are fitting a Honeywell T4360.
Fair enough but I'm thinking there also needs to be a pipe thermostat otherwise the central heating will be on constantly during the winter months trying to keep the loft warm so I'm looking at a Honeywell L641B.
Are these 2 devices supposed to work in conjunction with each other? What I'm thinking will happen is the pipe stat will kick the boiler on if the water in the pipe starts to freeze over, which is fine but wouldn't the room stat ignore all that and kick in the boiler regardless, constantly? Or am I missing something obvious here?
Peter
Peter
