new warmflow external oil boiler, heating is coming on randomly & regularly, I think the frost & pipe settings are incorrect but not sure what they should be & it is driving me nuts & costing me a fortune in oil
Frost stat is preset to fire boiler at usually 5 degrees. I suggest you insulate very well all pipes to/from boiler. The winter has been colder than usual and unless you have had these installed recently i would suggest they are working as they should....
