Frozen soil waste pipe
25 Aug 2006
Northumberland
Hi yes i have a frozen soil waste pipe.The reason for this i think is that i have a bathroom sink waste which is connected into it .This i suspect has dripped++++ causing the build up of ice and hence the blockage.The blockage is probably 2/3 feet down but is difficult to say.I've tried pouring boiling water down with little effect.The other problem is the pipe is cast iron.Any ideas?
As its iron then I doubt a hairdryer would have much effect. Hot air gun or blowlamp on lower setting might get enough heat into the pipe to start melting it a bit. Once you can get some water moving i'd put hot water down the bathroom sink to try and melt the rest of it away.
Lower setting on lamp :eek: we were using roofers torches and big bottles in that 80`s freeze - I blamed Maggie @ the time :mrgreen: mind you that was hanging soils under a car park so it might have been spun cast - bit like this spun tale ;)
