fsl on two contacts
Status
Not open for further replies.
The hand drawn diagram is not the same as the schematic from Scanny.
To solve the problem of both doors being open and causing a fault, follow the schematic....or get a bigger panel.
So go with this:
BTW what color wires are recommended for fsl? i use to use blue/yellow for loop and green/white for tamper.
I contacted Cooper Security for this info, they suggest the same as what I have:
Note there was the following warning/note with it:
"Cooper Security DO NOT recommend having more then one device per zone when using FSL wiring method."
I guess this is a “feature” of Scantronic’s design, where individual 4K7 resistors over individual contacts is the norm or norm for other panels.
For my needs, the diagram they sent, is the same as what I posted, so i am happy for this to be closed by moderators as the answer for this question and for anyone else to look at FOR THE SCANTRONIC 9752 PANEL.
Status
