- Joined
- 25 Jul 2022
- Messages
- 13,157
- Reaction score
- 1,042
- Country
Bad wording sorry. But the point stands
I believe all modern, common rail diesels have 2 fuel pumps, a low pressure high volume one close to or in the tank (a.k.a. 'Flow') and the second high pressure one under the bonnet feeding the common rail. Fuel that isn't used by the high pressure pump is returned to the tank as is the surplus in the common rail. Switch the ignition on (for the want of a better word) will start fuel moving in the low pressure pipe work.The system would already be primed, just not pressurised.
Not unless the engine is using fuel, which it won’t be if it isn’t running. Engine not running = fuel not circulating.Switch the ignition on (for the want of a better word) will start fuel moving in the low pressure pipe work.
Not always fully true. Disconnect fuel pipe with "ignition" on and fuel often flows= pressurised. But the flow returns to the tank.Not unless the engine is using fuel, which it won’t be if it isn’t running. Engine not running = fuel not circulating.
I think you know that if all is as is should be, it will be as I described.Not always fully true. Disconnect fuel pipe with "ignition" on and fuel often flows= pressurised. But the flow returns to the tank.
I've been around cars long enough to know things are not always as expected.I think you know that if all is as is should be, it will be as I described.
That would hardly be considered “unexpected“Disconnect fuel pipe
I’m out, you obviously know much more than me.I've been around cars long enough to know things are not always as expected.
Don't be like that. Share what you know. Maybe one day I will accidentally put diesel in my petrol.I’m out, you obviously know much more than me.
LawnmowerI don't see how else you can dispose of the contaminated fuel.
Try a siphon first.. If you push the pipe all the way til it stops but no resistance when you suck on the end of the pipe, there will likely be an anti-siphon mesh in the filler pipeIs this a difficult job and something I can do (heating engineer so may have some necessary skills for a drain down )
£25 of fuel isn't that much. Half or a full tank does become a much bigger issue to store, especially if at home.No experience. The guarantee will be along the lines of: done to required procedure. If the engine blows, that's at your own risk.
There may not be an option of not using a paid service. I don't see how else you can dispose of the contaminated fuel.
Won't happen. A diesel nozzle is too large to fit into a petrol car.Maybe one day I will accidentally put diesel in my petrol.
