hello,
ok after looking for 40a fuse wire to change the current 30a fuse used only by the shower, i learned it dose not exist.
can aneone tell me if its going to be possable to get a fuse to 40 amp on this fuse bourd?
the fuse bourd is made by centaur and has a max load of 80.
the reason i want a 40a fuse is for a new shower (30a only allows for a 7kw shower and i want to install an 8kw shower which will need 40a) so at present its running threw 6mm paired cable using a 30a fuse, so that needs to be 40a cable.
can anyone give me some advice please.
thanks
thanks
