I forgot to mention - the new landing light will be an emergency one, there's no way the gear will fit through an Armeg hole, and I need to screw it to a joist. Another reason for lifting the loft flooring.
And as much as I like tools, I can't see me being allowed to buy a Fein just to save me moving boxes in the loft, especially as (apparently) they're full of junk I'll never need, and perhaps instead of moving them about I could throw them away...
So I need to charge to do a periodic inspection before i can quote to replace in the CU?? Then do another test and inspect once the job is done?????????
