- Joined
- 25 Nov 2004
- Messages
- 98
- Reaction score
- 1
- Country
I’m renovating and combining a toilet and bathroom. Both rooms are down to bare walls, giving me the opportunity to improve the electrics, could you advise on the following.
· On a 2 gang light switch there is a supply in to the first common and a switched live out. From this common there is a link to the second common and a second switched live out. Is linking the commons acceptable?
· The lighting circuit doesn’t have any earths. I would like to install an earth in case a future fitting requires it. Should it be 1.5 cable 6491x ?
· I want to install a fused RCD connection unit for a spar bath. I can fit it as a spur or part of the ring as the cables are accessible but does it matter which way?
thanks & regards
thanks & regards
