Thanks for all the info, chaps - I was so consumed with sorting out a way to fuse the fan supplies that I didn't think about the run of cable coming from the shower supply to the fuses.
The shower isolator and the proposed SELV source for the fan are all outside zone 3, so presumably the fuses could also be there - i.e. contiguous with the shower isolator. This would mean a very short run (10-20cm) of cable to the fuses, and well protected, as it would be going from the inside of 1 box to another that was right next to it.
What do the regs say about insulation colours? I could use 3C+E as suggested by spark, but that would mean 1.5mm cable. If I use 2C+E, or singles, I could have 4mm cable - safer from an electrical viewpoint, but only black/red, (unless I can find some yellow sleeving).
The chances of anything going wrong with the short bit of cable twixt shower switch and fuse are pretty small, but I'd feel happier with 4mm protected by a 40A breaker rather than 1.5mm.
As for why I want to have the fan controlled by the shower switch, rather than the light, it's because I want to ensure the fan operates when the shower is on. My bathroom has plenty of natural light, so there is no guarantee that anyone using it will turn the light on, leading to the possibility (almost certainty in the case of the Inattentive 15-Year Old Dork, aka my son) that the shower will be run without the fan. I agree that it's more likely that a shower switch would be left on rather than lights (extremely likely in the case of IFYOD), but I'd rather have the fan running when not needed than vice-versa....
