Galaxy 16+ manual
all the keypads beep, but they are not very loud, thats why it has a speaker option
i gotcha. so you dont think i should bother with the internal sounder? just get a 8ohm speaker?
there is no official connection for an internal siren.
but there is for a speaker
oh, guess what
this button is for? (makes reading posts easier)
Ok breezer thanks for that. I think the internal siren was connected in parallel with the external before.
thats a bad thing to do.
if all 4 wires are connected in paralel it stops both the external and internal sounder's tamper from working
what you on about? you`ll confuse the O/P if your not carefull
parallel the internal siren across 12v and trigger will work fine, one thing you should check first is that if you DO use a speaker the tones may be too loud
Thanks for your Input Atilla I personally think that the tones from my keypad will be ample as this will be fitted in the hallway.
So i can fit the internal siren aswell as the external! gr8 i can defen the beggers if they try comin in.
most people will connect all 4 wires in paralel, which will as i said stop both sounders tampers from working, think about it.
+, - , ringer and.............. return.
each return will send a -ve back, so in order for the alarm to notice something is wrong, you will have to remove BOTH tamper returns.
That is what i am "on about"
daweorama, you can connect the internal siren as well, i never said you cant, what i said is
you will end up with 8 wires 2 of each of four colours, naturally you would connect them up in pairs of same colour, it will work, but if any one tampers with either siren , the panel will not know.
The thing is that you do not pair them all up.
might be a six core (or an eight) and only five are used - oooh scary, like I said stop confusing the issue
INTERNAL SIRENS CONNECT ACROSS THE 12V AND THE TRIGGER - job done
i never said they dont.
i am saying that if its using 4 wires...............
it would be a common mistake to make.
I would also still suggest a speaker as oppsoed to the internal siren so if there is a tamper fault and the tv is on at least you will know about it.
the external sounder will only activate if the alarm is set
unfortunatly thats incorrect too, bellbox tampers or panic activations? to name a couple of possible triggers, there are others but I dont want to confuse the O/P
nothing personal
nothing peronal taken, if you see what i mean.
try it and see, you will find on a galaxy you are not correct.
pa will set the bell off as you say (unless its silent) but a tamper, line fault, low battery, rio missing, etc wont set the external sounder off if unset.
thats true, but as I said somethings will.......guess you dont live next to someone with a 700L, evil panel that is and everytime they activate the chime it shakes the plates off the wall LOL
interestingly ADT have gone over to not using loudspeakers on domestics now, wonder why?
