Dear All,
First time post so apologies if I repeat something shown elsewhere. I have a Galaxy 18 fitted at home by the builders when the house was built 12 years ago. I don't use it much but it always worked perfectly ok. Had the stand by battery replaced about 5 years ago by an adt chap cash in hand who came to do the system where I work. Recently got the quick flash on the panel light so assumed I needed to replace the battery again but did it myself this time sourcing the same battery from Amazon.
All worked fine and the panel light constant and system functioning ok so no problems. Three weeks later we had either a very short power cut or a surge which tripped the consumer unit and fused the toaster and appeared to factory reset the Galaxy system. Since then I've had ongoing problems with a telecoms failure and a line fault and after pulling the engineers manual off the net have sorted both these problems but have had two further power cuts recently and the alarm has just instantly sounded and performed a hard reset as though the stand by battery somehow isn't working. I can't see anything in the manual suggesting that I need to 'switch on' the stand by battery or that the default is not to use the backup supply, but each time we have the power cuts it resets all the defaults and the system then thinks the phone lines have been cut so after about 30 minutes the alarm activates, even if it isn't set. I'm not getting any warning lights on the panel, so assume mains supply to be good, backup battery to be good and no internal fuse problems but it's still not happy.
I can reset the telecoms failure again but the next power cut will hard set the system and restore defaults and the alarm will sound for the duration of the power cut. Would welcome any thoughts anyone might have on this and for ref, I have no electrical training, and haven't seen any adt chaps working on my work system to ask.
Rob
Rob
