First of all, thanks for your reply.
Galaxy Dimension 96 FW version 6.94
2 external RIOs both with version v1.00
It's also worth noting that different RIO firmware versions have different capabilities regarding zone resistance, so the panel may behave differently when adding an old firmware version peripheral.
Since most high resistance issues are with detectors wired to the external RIOs, it seems to me this might be the problem.
Can a RIO fw be updated?
They don't seem to have a port, but maybe via the panel SPI Program Header?
By the way, I forgot in my previous post, the external RIOs blinking led rate is
Ext. RIO blink light rate
www.diynot.com
Does it seem OK?
It comes now to my mind, as for the panel fw update, from the beginning I sometimes get a fault message (Low Volts RIO100), when I have a power failure.
I don´t know if it is related, but onboard detectors that had high resistances issues were wired to RIO1.
One of the experiments I did was, after disconecting everyting, I tested DT detectors (with relays) wired to RIO0 and RIO1. During the test period (23 days), I had no high resistances issues. The only problem is that onboard detectors rarely have this issue, which are very frequent with detectors wired to external RIOs, so any conclusion might not be valid, except if I test it for several months.
You've once told me this was a fw issue. Has this been addressed yet in recent firmwares?
From what you say, you've narrowed down to the sensors by placing a 1k resistor across the zone to 0v in the sensor head. If that's the case, then check that the detectors themselves are a dead short across the NC to 0V and fully open circuit when triggered. Some sensors have additional resistance in the relay circuit (not including any built-in EOL) and you don't want that. The sensor is a basic switch, so should be a dead short and fully open when triggered. When you replaced a sensor, did you select a different type ?
Sorry, not sure I understand what you mean.
I opened a sensor, disconnected the zone wires from the sensor and closed the zone with a 1K resistor between those 2 wires, inside the sensor, as is the sensor wasn't there.
When I replaced a sensor I used a new identical one in case the sensor might be faulty, but then again, I would have more than 10 faulty sensors.
