Galaxy Flex siren not working.
Hi yes wiring was connected as you say, when I first enabled the module the led did not illuminate. I reconnected the module and enabled again and now it works. Bit confused at what the issue was as the connections where as the instructions. Thanks for taking the time to look into this. Is connecting a dialler as simply as using a trigger connecting to dialler trigger input and programming as say intruder in panel? Are resistors req?
Sometimes insulation can get in the way in the screw terminals making a poor connection.
Can I clarify something regards connecting a dialler to the output module, I have 3 inputs on the dialler and I want to connect 3 triggers programmed intruder, pa and tamper. Is this possible and do i need to connect a resistor in series with the triggers.
