Building regs were involved and I feel like the correct insulation was used at the time.
We shut the garage conversion off on the night to stop the cat going in there and vomiting on the floor.
The heating is not on overnight. The heating is only just going on for the first time today.
When I've opened the garage conversion room the last 2 mornings it has been 2 degrees colder than my open plan living room (with a staircase in it). Id expect my open plan lounge to lose far more heat overnight than my sealed garage conversion.
The garage has 2 external walls, one newly built to replace the original garage door, cavity with rockwoll insulation. The other external wall is part of the original house and has retrofitted cavity wall insulation (I've seen it, looks ****e but its there and same as what's in the rest of the house walls).
There's a lean to roof above the front half with 200mm + of rockwoll. The back half of the room has a bedroom above it.
Floor is raised with 100mm celotex, timber floor and carpeted.
It has 2 double glazed windows with trickle vents.
The room warms up okay once the radiator goes on but I don't understand why it's 2 degrees colder than the rest of the house in the morning?
