Sigh. All points missed. Do you know what a vapour membrane is? Let's start with the basics.
Eh?It's an impermeable membrane that should be between the room and the insulation.
Warm damp air can get to the internal face of the insulation, but not beyond it to the cold side.There's a transition of temperatures across the cavity - from room temperature on the inside, to outside temperature on the outside.
If you let that warm damp air from the room get into the insulation then it's likely to condense at some point, which will cause damp, rot and smells.
No he's not, a VCL is a not a vapour barrier they are not the same things. You fit a Vapour Barrier behind plasterboard, that is an impermeable membrane not a Vapour Control Layer which typically is not airtight. If you wanted you could swap a VB for a DPM fitted imediatly behind the PB in a wall situation they would achieve the same thing.Eh?
Are you confusing vapour control with a DPM? It sounds like you are.
Vapour should not migrate from the warm side to the cold side - VCL - fitted behind the plasterboards via sealed PIR foil coated boards with foil tape etc.
Damp/rain/water should not permeate into the internal structure - DPM (impermeable membrane or visqueen)
The wood is at room temp, due to the continuous layer of insulation, separating the wood and the garage wall.Does it need a vapour barrier under the plasterboard, to stop moisture migrating from the room condensing within the wood?
With regards to my image I posted, the black polythene is acting as a DPM. The foil tape is dealing with the vapour etc. I'm a bit lost on Windy's explanations and terminology in respect to that.No he's not, a VCL is a not a vapour barrier they are not the same things. You fit a Vapour Barrier behind plasterboard, that is an impermeable membrane not a Vapour Control Layer which typically is not airtight. If you wanted you could swap a VB for a DPM fitted imediatly behind the PB in a wall situation they would achieve the same thing.
Not inside a sheet of aluminised kingspan you won't. WUFI can claim the dewpoint is in the middle of a big block of PIR all it wants; you aren't going to see water dripping out the bottom of itIf there isn't one you'll get damp within the insulation.
No. Go and look up the definition of "cavity" in a decent dictionarya cavity .. happens to be full
Not if the insulation is detailed correctly, as in how I showed it in the image, ie. a continuous layer of insulation behind the studs. The timber with then be 'warm' as in the same temperature as the room.If that block of insulation includes wood then it will rot, treated or not
Nonsense. It's how ALL warm roofs are detailed. So a wall with a continuous layer of insulation across it, protecting the timber studs, is no different in that respect.I disagree. The timber will be colder than the room
