You do need to confirm that there are no drain leaks, and to do that you need to CCTV all drains near the garage - it is very important to check all nearby drains. For this you will need to trace all drains and confirm where all the drains are, and trace them from every down pipe and gully and soil stack connections on both houses. There might not be any soak-a-ways, but the only way to tell is to check were all the rainwater pipes are running.
The CCTV company will produce a plan showing the condition of all drains and their locations/depths within both of the gardens.
Also check the garage to see where the roof run-off is going. If the roof is on a slant and all the rain is running down that wall, then the ground will be saturated, and if sand or loose fill, then liable to compact.
Holly is on the list of potentially problematic shrubs, and can dry out soil within a 5m radius. But its just a possibility at this stage
Potentially, there could be a local pocket of poor ground under that wall. It might be an idea to dig a hole at the four corners to check the foundation depth and whether the ground is any different at each corner. If you get an engineer involved, then that's what he would do, and also take some soil core samples along the wall.
Its very important to find out the cause before even thinking of a remedy. Ground can move back and walls lift once moisture is stabilised, underpinning is commonly thought of, or ground grout injectionis possible. But no-one will suggest a remedy without knowing the cause. It may be that once the cause is known, if no more movement is anticipated, then the door can be re-aligned and the roof levelled up to avoid costly foundation work.
You need to get that CCTV survey re-done before you can move on. A local engineer might be able to give you some more definite advice from a site visit, but he will most certainly advise drain and ground reports.
