Garage lights
19 Nov 2014
Avon
Hello
Turned the isolation switch off on the garage consumer unit for the lighting circuit, 3 outside security lights, fluorescent lighting inside the garage, due to replacing an outside SL bulb and now the light switch in the garage for the fluorescent lights is working the opposite way.
Any ideas?
Is there another switch for the fluorescent lights at the other end of the garage?
Have you changed the switch plate at all? I put one back in upside down last week - Doh.
The opposite way to what? The consumer unit?
To turn the garage lights on the light switch was pressed down for on up for off, now it has reversed, I have not taken the switch plate off, all I did was turn off the isolation switch for the lighting circuit on the consumer unit, and the isolation switch for the outside security lights.
